WD45 Shifter
alex7407
06-06-2006 18:57:23
Does anyone know anything about a WD45 shifter jumping out of the forks. It seem when I put it in 4th gear, the shifter pops out of the forks and you either have to fish around, or take the whole rod out to get it back in.
Brad Wright of MO
06-17-2006 20:08:41
 Re: WD45 Shifter in reply to alex7407, 06-06-2006 18:57:23
That also happens when you try to force it in to gear. You may not think your forcing it but it only takes a little bit to pop that bearing.
John (C-IL)
06-06-2006 19:18:57
Pretty common problem when the shifter gets worn and has been cussed and discussed here. If the problem is just a worn shift lever it is a pretty easy fix with a little welding and grinding. If the forks, gears and or bearings are worn the solution is somewhat more complicated.
