WD vs WD-45 final drives
85_Ranger4x4
06-16-2006 07:39:15
Are the final drives interchangable between a straight stick WD and a Wd-45?
Kraig (WI)
06-17-2006 18:48:52
 Re: WD vs WD-45 final drives in reply to 85_Ranger4x4, 06-16-2006 07:39:15
I hope they are the same. I have a set of WD final drives torn down to rebuild and put on my WD45. My WD45 has bad pinion bearings, so to reduce down time, I'm rebuilding the WD final drives to bolt on to the WD45. I measured them up and everything looks the same. Kraig (WI)
Tramway Guy
06-16-2006 12:29:48
I think that the rear wheel axle is slightly beefier on the WD45, but I think the gears and splines are the same. I remember when I broke one on a 45D (using a D17D engine and clamp-on duals pulling a 4-row no-till planter), we could only find a regular WD axle. It was not quite as meaty in the flange area, but it still fit.
85_Ranger4x4
06-16-2006 10:16:20
The big reason I ask is a guy I was talking to said they had different gears inside. Just wanted to make sure.
JMS/MN
06-16-2006 08:43:02
Yup; according to my AC mechanic buddy, lotsa parts are also used in the D series tractors.
Phil Auten (TX)
06-16-2006 08:32:45
I believe they are, but someone more experienced than I am should confirm.
Phil
