d17 oil leak
Alan Haley
06-19-2006 10:28:37
I got an oil leak on my AC d17 in the front. Looks like its coming from the cover of the timing gear, right near the front engine mount. You can only see it from underneath the tractor and it only leaks when the machine is running. Two questions; 1.the shop manuel does not say a lot on this except to get under the timing cover and use gasket sealant to fix the leak. Does this sound right or should I be thinking about putting some sort of seal in?
2. If I split the tractor and pull the front off can I do so and leave the engine bolted up to the transmission without any front support?
I have a fair amount of experience in rebuilding old pickups but this is the first time I have worked on a tractor.
