Allis Chalmers B Sickel Mower
Allis Nut
07-11-2006 19:55:57
I just purchased a sickel bar mower for my 1948 Allis Chalmers B Tractor, the person that I bought it from had it on a C But am hoping that it will fit. The question that I have is how to find out what model it is, I do not find it written on there any place, and I would like to get a manual for it. If it helps it goes underneath and bolts on the the drawbar and then bolts up front on the housing. it is manual lift. And the pully that goes on the PTO has two drive belts. And also does anyone know where to get parts for it I need the whole swath board and some guards as far as I can tell so far. Thanks For The Help
Rod (NH)
07-12-2006 12:49:23
 Re: Allis Chalmers B Sickel Mower in reply to Allis Nut , 07-11-2006 19:55:57
Hi,
Odd name you got there. It's not a B/C mower if it uses two drive belts. I understand the CA #5 mower will fit and if it came off a C, it should also fit your B. Depending on the drive pulley, you may or may not have to make some accomodation for it to fit your PTO shaft, as Jerry indicates. Getting guards and knife sections shouldn't be a problem since new foreign knock-offs are available. You can try an AGCO dealer or some farm supply stores/sites. I suspect the swathboard is the same on the #5 mower as it is on the B/C mower but am not sure. The B/C wooden swathboard (and grass stick) is easily made. I have produced a working drawing for making an original replacement B/C swathboard. That's available from this link. If you don't have any mounting hardware for the swathboard or the grass stick, those items probably will be hard to find new from any source since they are not normal wear items. You might get lucky and find some of those as NOS but more than likely, you'll have to locate used ones or cobble something together that at least works.
third party image Rod
Jerry Coulter
07-12-2006 10:00:55
If the drive and driven pulleys take 2 belts, then it must be a #5 mower designed for the CA, and will fit the B & C. Hopefully, the PTO pulley has the correct size spline to fit your tractor because the CA and late B have standard 1 3/8" while the older B and all C's have 1 1/8" spline.
old
07-11-2006 21:53:49
Drop me an e-mail and I can send you a manual for the one I have on my C which should be close to what you have.
