AC
model D Grader
Thomas
08-28-1999 11:12:02
Looking for parts and inf. on Model D Grader. Magneto - overheating - solutions? Also, thinking of replacing motor - any ideas??? Thanks
bentorbroke
08-28-1999 21:13:04
 Re: AC - model D Grader in reply to Thomas , 08-28-1999 11:12:02
Hi, is the AC - model grader built similar to a WC tractor with an extended frame? If so I think it uses the same Engine as the WC. Anyway, if it is running hot and has a magneto, you may want to check the impulse spring inside the impulse coupling that "preloads" the coupling. If this spring is broken the engine will start as normal with 0 degrees spark advance and run that way instead of advancing to 30 degrees advance when running. This will cause the engine to run hot (very hot). If in doubt, check the timing during starting and under high idle running conditions. Good luck, have fun bentorbroke
