1954 wd or w45
Al Bramley
08-02-2006 08:29:50
I just purchased a 54 wd or w45, i am looking for a rad and 3 pt hitch parts, all I have is the lifitng bars. I took the rad to a shop here locally and they wanted $400.00 cnd to recore it, so i am wondering if its any cheaper to buy a replacement or will something else work.
Thanks!
85_Ranger4x4
08-03-2006 07:41:14
 Re: 1954 wd or w45 in reply to Al Bramley, 08-02-2006 08:29:50
They used WD engine blocks in the early WD-45's, the easiest way to ID them is the serial #. It is on the back of the differential below the left brake cover.
old
08-02-2006 09:15:12
I have a good used one from a parts WD I have. Also to tell if it has a WD or WD45 engine look on the right side of the engine. If theres a plate that bolts on to that side its a WD engine and if it doesn't have that plate its a WD45 engine. The serial number for it is on a flat spot on the left side of the rear end just below the brake cover plate.
Dandy Don
08-02-2006 08:37:46
Al, At the top of this page is a block ,enter your model, click view and scrold down to check what products are available for your tractor and some are bargins and YOUR raditor is $190.00.Lots of things you probably can use/need. Don
Al Bramley
08-02-2006 09:48:08
 Re: 1954 wd or w45 in reply to Dandy Don, 08-02-2006 08:37:46
Thanks a bunch Don!!!
