WD45 Radiator Hose Leak
Alex7407
08-03-2006 18:27:44
I'm almost done with my WD45. I put new radiator hoses on and one, no matter what I do, continues to leak just a little bit. It is the top fitting on the lower hose. What causes this?
Texas Denny
08-04-2006 12:28:47
 Re: WD45 Radiator Hose Leak in reply to Alex7407, 08-03-2006 18:27:44
I agree with Jerry. It is probably not the hose. May have a pin hole in the metal portion of the connection. Or the seal on the water pump is leaking. I assume your new hoses are the correct size.
Jerry Coulter
08-03-2006 19:08:40
Look real close and see if the leak is coming out of the weep hole in the water pump.
