WD Hydraulics
Al Bramley
08-08-2006 08:13:43
Any ideas on splitting the huydraulics on a 54 WD45, what I want to do is to seperate the front end loader from the 2 point hitch, also I am going to put a ram on the bucket and I have been told that I need to do that from the hydraulic pump??
Thanks
Al
Jerry(mo)
08-08-2006 08:47:47
 Re: WD Hydraulics in reply to Al Bramley, 08-08-2006 08:13:43
this is what I did
Texas Denny
08-08-2006 10:47:10
 Re: WD Hydraulics in reply to Jerry(mo) , 08-08-2006 08:47:47
Sorry, Jerry, about calling you Al. Got confused and picked picked the wrong name when giving my reply. Again, good work!
Texas Denny
08-08-2006 10:44:06
Al, to get this to work, don't you need to have the lever by the steering wheel in the lift position at all times that you need hydraulics? Seems like a great fix. You have one valve for the lift arms in the back and one valve for the loader in front. By adding a third valve, you could add hydraulics to the bucket (done this on two tractors - Ford 9N and 971). I've always thought this was possible with the WD/WD-45 but never had the reason to try it. EXCELLENT!
Jerry(mo)
08-08-2006 11:18:46
 Re: WD Hydraulics in reply to Texas Denny, 08-08-2006 10:44:06
yes you keep the wd45 pump lever up all the time and it pumps in a circle with no pressure. When you activate a new valve the fluid goes down that hose and builds pressure. A WD pump runs all the time anyway it just has a internal bypass the lever by the steering wheel just opens the orginal valve to send the fluid down the hose, in my case it goes back to the drain plug.
