WD 45 Hydraulics
Al Bramley
09-24-2006 11:00:27
I have changed the hydraulics over om my wd 45.
I removed the hoses off of the pump for the 2 point and couled them together as i do not need it at this point, purchased a 3 spool valve and ran a line off of the output on the pump to the spool, then i teed into the drain plug with a tee and fed a return line from the spool to it.
Then ran a single line to the loader rams and it works fine, the problem i am having is this, i ran 2 lines off the same valve but diffrent spool to a double acting cylinder i installed on the bucket, but i cannot get the cylinder to operate both ways, it appears that I am only getting fluid to one end of the cylinder, is it the cylinder possibly, i am at my wits end here so any help would be greatly appreciated. Thanks, Al
Al Bramley
09-25-2006 09:10:55
 Re: WD 45 Hydraulics in reply to Al Bramley, 09-24-2006 11:00:27
OK, so I really feel like a goof, I had a plugged fitting!!!, sheesh!, after 3 days of messing around and a few swear words later I finally figured it out, thanks for the replys and the help!!!
MikeRW
09-25-2006 07:06:03
Trying to attach again.
http://wd45.mustangserver.com/
MikeRW
09-25-2006 07:04:42
Al,
Check out this guys website. He did something very similar as you did. Maybe this will help. Looks very interesting to me. Wish i had a few bucks to give it a try.
bobodu
09-24-2006 15:09:01
Are you sure the spool is for a double action cylinder?
Kinda of embarassing....but I messed with one I built for a week before I realized the valve stack was from a fork lift.
