7050 shifting problem
AC 7050
10-08-2006 19:47:04
I got a 7050 with power directer. The hi low shifter in the console will not shift into hi or low. Feels like nothing there. So I replaced the hi low cable and also park cable. I noticed that under the cab where the shifter stands out of the top of the case that the shifter turns instead of rocking back and forth to shift the gears. After further investigation I noticed that the round piece that the shifter sits in that the rubber boot is attached to also turns in the case. I took the snap ring out and pulled the shifter out. But now how does the round piece come out of the case? What holds it in the case? I can turn it all day long and cant get it out.That piece is not supposed to turn is it? I tryed to pull it out and cant get it. Thanks in advance for any help.
856 puller
10-09-2006 18:24:12
 Re: 7050 shifting problem in reply to AC 7050, 10-08-2006 19:47:04
does the shift lever move the cable? if i rember right there is a small cover in front of the rockshaft. you will have to take the cab floor out. once that cover is off you should be able to look around and see whats up. the shifter is on the round cover on the right side of the rear end probally behind the extra fuel tank if there is one. make sure you clean up real well before you take the cover off the range trans. good luck
