Unstyled WC fender woes
AC
10-10-2006 17:11:29
I am trying to figure out how to mount a set of old style fenders on my unstyled WC. But I cant figure out how. Do I need a cast bracket like the newer WC's have that mount to the rearend and fender? Cause I dont have any. If thats what it requires, does anyone have a set for sale?
Question 2 ....This motor is suppossed to be a WD 45 motor. The serial # says WD339XXX . Is there a casting # or anything I can go by?
thanks, AC
JMS/MN
10-11-2006 07:02:42
 Re: Unstyled WC fender woes in reply to AC, 10-10-2006 17:11:29
The cast bracket on top of the brake housing is not the same between styled and unstyled WC tractors. If my memory is right, you use a forward hole on one bracket and a rearward hole on the other- only one hole per fender. There is also a half inch diameter rod between the tractor frame and the lower front of each fender. Those rods are easy to make- just determine the length and thread each end. If you find thed right brackets, make sure the 'ears' of the holes you need are not broken off- otherwise you need to weld a nut in place to manufacture a hole in the correct location.
JMS/MN
10-11-2006 12:40:31
 Re: Unstyled WC fender woes in reply to JMS/MN, 10-11-2006 07:02:42
Mounting update: Left and right side brackets are the same on an unstyled WC, but have only one 'ear'- that's why one is forward, one toward the rear. Fender also has a couple bolts to the rear of the axle, lower edge of the fender.
John (C-IL)
10-11-2006 05:25:31
You have a WD motor. The WD45 motor serial number starts with a 45-XXXXX. It is possible that your motor has 45 parts inside.
AC
10-11-2006 23:21:59
 Re: Unstyled WC fender woes in reply to John (C-IL), 10-11-2006 05:25:31
THANKS GUYS! Now anyone have a set of fender brackets they dont need?
old
10-10-2006 17:44:14
If its a true WD-45 engine there will be no side plate on the right hand side of the engine that bolts on. Now if its a WD engine with WD45 parts in it there will be that side plate on the right side of the engine.
