wd or wd45?
a-1septic
10-28-2006 05:53:40
I just bought a ac tractor serial #wd148942. Is this a wd or a wd45? Thanks
a-1septic
10-29-2006 05:38:22
 Re: wd or wd45? in reply to a-1septic, 10-28-2006 05:53:40
Thanks guys it is a wd45!
Jeremy
old
10-28-2006 08:53:39
From what John says its a WD45 but it could have the wrong engine in it which could make it a sort of between. If the engine has a bolt on side plate on the right hand side its a WD engine in a WD45 frame/tranny. I've seen so many of these WD and WD45 tractors that have had the engine swapped that theres so many thing you need to look at to be sure what it is or isn't.
a-1septic
10-28-2006 10:38:40
 Re: wd or wd45? in reply to old, 10-28-2006 08:53:39
the numbers on the side of the engine are castted into the side of the block there is no bolt on tag.
John (C-IL)
10-28-2006 06:28:10
WD45 serial numbers start at 146607.
