allis chalmers wd, 3,000lb?
AC Power
12-04-2006 18:38:23
hello, been thinking about buying a WD allis chalmers to tractor pull with. I am writing to find out if there is any way possible to get a wd down to 3,000lbs with about a 150lb driver on it. so the wd would have to weight 2,850lbs. can u get one that light? and if u can how do you do it? thanks, jason
John (C-IL)
12-04-2006 19:40:10
 Re: allis chalmers wd, 3,000lb? in reply to AC Power, 12-04-2006 18:38:23
The shipping weight is listed as 3338#, so dropping 500 pounds shouldn't be too big of a deal. Remove all non essential steel, run minimal fluids. use the lightest tire and wheel combinations you can find and you should be in business.
time to quit
12-09-2006 07:43:57
 Re: allis chalmers wd, 3,000lb? in reply to John (C-IL), 12-04-2006 19:40:10
loose the fendersand pto first then i changed to rear rims from a 37 wc and dont forget that worn out tires weigh alot less and on a dry track 25% tread i think pulls better than new. i weigh 145 and i make it with 30lb to spare with 5 gallon of gas.
