Allis G Front wheel Bolts.
AWB
12-23-2006 18:00:40
What is the correct length for the bolts that attach the front wheels to the front rims? Are they originally a square head bolt or a conventional hex headed bolt? The Parts Book does not show a lock washer being used. Is this correct or an oversight? Thanks, AWB
Texas Denny
12-24-2006 06:52:56
 Re: Allis G Front wheel Bolts. in reply to AWB, 12-23-2006 18:00:40
Never seen a wheel on the front of an Allis tractor with lock nuts on the wheel to hub. The G certainly does not have locknuts. As far as length, I think they are 3/4". They are long enough if there are enough threads for the end of the stud to protrude from the inside of the hub.
Joe M(GA)
12-24-2006 07:11:46
 Re: Allis G Front wheel Bolts. in reply to Texas Denny, 12-24-2006 06:52:56
They were square headed, McMaster-carr should have them if you can't find local.
3/4 sounds about right, I'd go measure for you but mama said no more tractors or working in the shop until after Christmas
Texas Denny
12-24-2006 10:27:01
 Re: Allis G Front wheel Bolts. in reply to Joe M(GA), 12-24-2006 07:11:46
Whoops, I'd forgot about the way those wheels are done. Yes, The bolts are square but my nuts were hex. And, yes, they have lockwashers. Not sure about length.
