170 diesel low on power
acdave
12-23-2006 20:52:12
i have a 170 diesel that does not have the power i think it should it smokes a little more than i like and today grinding feed it looked like it might be leaking a little oil at the head gasket it seems to run fine but has a little noise in the exhaust and it seem like it is sucking a lot of air through the intake
acdave
12-24-2006 13:43:06
 Re: 170 diesel low on power in reply to acdave, 12-23-2006 20:52:12
i put a new air filter in and adjusted the valves that helped a little but did not fix the problem i then took the injectors out i am going to take them to agco dealer to check out after the holiday one injector was all rusty the other 3 were wet with oil want to take the head off but it seems stuck i may need to pull the studs to get it off thanks for the reply's who knows when were done we might have a nice little tractor David
Aaron SEIA
12-26-2006 14:20:44
 Re: 170 diesel low on power in reply to acdave, 12-24-2006 13:43:06
Thatnks for the update, let us know what you come up with.
Aaron SEIA
Aaron SEIA
12-24-2006 10:08:16
Also, not to make you sound stupid, but...smoke, low power, the extra exhaust noise and the sucking in the intake might be signs that the air filter is severly plugged. Checking that is free and new ones are cheaper than an OH. If that is ok, then I'd go w/Texas Denny's route.
Aaron SEIA
Texas Denny
12-24-2006 06:57:24
How many hours are on the tractor? Could be it is ready for an overhaul. If oil is coming out around the head, you probably need a head gasket. While you've got the head off for the gasket, may as well grind or lap the valves.
