block heater for XT190
accrush
01-22-2007 17:18:21
Need to know where the block heater goes on a XT 190 diesel. It is a factory internal block heater with two bolt holes in it. Was told need to take cover off with two bolt holes some where on block need to know location of cover
Hurst
01-22-2007 19:28:07
 Re: block heater for XT190 in reply to accrush, 01-22-2007 17:18:21
The factory heater on my 7000 with a 2900 engine is mounted on the tractor's right rear side of the engine. It is held on by two bolts below the exhaust manifold next to the oil cooler. I will try to e-mail you a picture of where it is mounted.
Hurst
Bob
01-22-2007 19:07:41
My "Zerostart" engine heater catalog shows the two-bolt heater for 180, 185, 200, 7000, 7010, and 7020 tractors with 649, 649T, 2800 and 2900 engines.
It says the heater mounts at the RIGHT REAR of the block, with the element facing forwards.
For the XT-170 and XT-190, they list a 600-Watt, 1-1/2" lower radiator hose heate, FWIW.
Bob
01-22-2007 19:07:32
Larry in Pa.
01-22-2007 18:52:44
The 190xt that I used to have had a heater mounted in the lower raditor hose.
