hard starting wd
A-C hay man
02-05-2007 17:44:34
My WD is hard to start after it is warmed up. It turns over good, is getting a spark, but just won't start. It starts pretty good when cold. I also have a 68 GMC with the same problem. thanks
L'Burg Dave
02-06-2007 04:07:36
 Re: hard starting wd in reply to A-C hay man, 02-05-2007 17:44:34
I know that condensers can cause a hard start problem when they start to go bad. Usually, they just quit until they cool off. If you have an old one around you might try changing it out. Dave
old
02-05-2007 18:12:01
If the carb is set to lean or way to rich it can cause that type of problem.
