D-17 vs. WD
AC Newbie
02-15-2007 18:06:39
Hi all, new to AC's. Can anyone tell me if the deck height (from centline of crank to top of block) is the same on a D-17 as the WD or WD45?
Thanks
Kip[UT]
02-18-2007 05:49:37
 Re: D-17 vs. WD in reply to AC Newbie, 02-15-2007 18:06:39
The answer is yes. WD45 block & D17/GleanerE blocks are pretty much the same block except the 17/E blocks use larger main bearing size than the W series blocks. That's why you can stroke a WC or WD w/ a 45 crank but not w/ one out of a D17.
