dirty fuel tank
Al47
02-25-2007 15:13:46
Is there an easy way of cleaning a fuel tank on a 180 diesel?This tractor has been sittng for years.We redone the engine with new piston-sleeve kit--was rusted solid.Have gotten it running rather well,but there is alot of crud in the tank.It runs out of fuel because the lines plug.We can't continue like this because I know evetually it will mess up the injector pump.Any comments will be appreciated.
Thanks Al from Maine
patsublett
02-25-2007 18:35:59
 Re: dirty fuel tank in reply to Al47, 02-25-2007 15:13:46
Take it to a radiator shop. They can boil it out with acid, presure test it, and fix any leaks
fordtractor2000
02-25-2007 15:20:30
take the tank off and then throw about a pound of 1/4 inch nuts and a gallon or so of fuel then shake the living s**t out of it, that will loosen up the junk then you mite want to try the prep/sealer that they sell to seal the tank after it is clean.
1755
02-26-2007 15:30:28
 Re: dirty fuel tank in reply to fordtractor2000, 02-25-2007 15:20:30
The best way I found to clean out a tank was to get about a gallon or 2 of rocks that are hard not gravel and strap it to the back of a ATV and find a good kid and put him on there and have him run around on a ruff disk field to get a good bounsing for a half hour or so then flip tank over and repeat
