AC 170 engine stops running?
Chappy
09-24-1999 20:46:30
I have a AC 170 that runs for a little while then stops running. There is a slight knock in the rod or crankshaft area. The engine appears to lock up after about 10 minutes. Has anyone else been through this problem or do you think I have a bad main or rod bearing? Also where is a good place to buy a engine rebuild kit for this AC tractor.
Thanks
Chappy
Glen
09-26-1999 10:51:48
 Re: AC 170 engine stops running? in reply to Chappy, 09-24-1999 20:46:30
Sounds like your oil pump is bad. I would get a manual guage and screw it in the block where your sending unit is screwed in and see iif you getting oil pressure. Not shure but I would guess you should get at least 40# of pressure. Your dealer should be able to tell you this. You certinally should not run the tractor. If you have just bought it used, it is possiable someone stuck a new set of bearings in and they are to tite.
John
09-25-1999 11:16:57
Gas or Diesel?
