Valve ajustments
A/C Boy
03-19-2007 16:40:40
Does anyone know how to adjust valves in a new reworked head? Where do you start? Need Help
tim[in]
03-20-2007 15:16:00
 Re: Valve ajustments in reply to A/C Boy, 03-19-2007 16:40:40
d*mn! ive been in hospitals that werent that nice!=)
Dave Anderson
03-19-2007 17:11:24
Get the shop manual from Agco, and follow the directions-that's the best way.
A/C Boy
03-19-2007 16:42:58
My tractor is a d-15 series 2 160 cu in gas engine. Forgot to put that in my first e-mail
Dick L
03-19-2007 17:11:08
 Re: Valve adjustments in reply to A/C Boy , 03-19-2007 16:42:58
You start by having a feeler gage, a 5/8" box end wrench, and a screwdriver. Next the get number one piston to TDC on the compression stroke. That will have both rocker arms up as high as they will go. You then take the 5/8" box end and break the lock nut loose on one rocker arm. With the wrench on the lock nut you take the screw driver and adjust the gap between the rocker arm and the valve end so the .012 gage will slip thru snug. You then lock the adjusting screw by tightening the lock nut. Next do the same to the other rocker arm on number one cylinder. Move to number two cylinder and do the same at top dead center. Next jump to number four cylinder and do the same again. Then go back to number three and do the same. At this point you can start the engine and warm it up. While warm torque the head and then reset the valve setting to the book setting. Without looking I think it is .010 but .012 will work as well.
Dick L
03-19-2007 18:51:09
 Forgot Most Important Part in reply to Dick L, 03-19-2007 17:11:08
Proper duds to give the job the respect it deserves.
third party image
