Valve Adjusting Instructions
A/C Boy
03-21-2007 05:45:52
Does any one have the valve adjusting Instructions from a manual that you could post? unit: Allis Chalmers D-15 series 2 160 cu. in gas engine.
Dick L
03-21-2007 08:37:18
 Re: Valve Adjusting Instructions in reply to A/C Boy, 03-21-2007 05:45:52
If you can not figure out how to adjust the valves from the instructions I gave below then a manual will not help. You need to have someone that has done it correctly before stand and watch over you as you do it the first time.
A/C Boy
03-23-2007 18:07:49
 Re: Valve Adjusting Instructions in reply to Dick L, 03-21-2007 08:37:18
Dick L, how about weighing in on my brass fitting question. I wonder what your take is on that one?
A/C/ Boy
03-21-2007 16:41:37
Dick L I must be missing your instructions below? I just thought it would be nice if someone had the instructions and posted it. Someone on the International site posted it. Take a look at it. (nice) Link
Dick L
03-22-2007 08:17:19
 Re: Valve Adjusting Instructions in reply to A/C/ Boy, 03-21-2007 16:41:37
That chart is really nice so you can set the TDC two times and set all valve lash. That is really helpful if your tractor is a Farmall with a firing order of 1-3-4-2. With your tractor having a firing order of 1-2-4-3 using that chart might get a bit comfusing. I am old but still do not have a problem of turnning the crank to TDC on the compression stroke four times while setting the valves. Good luck in any case.
Dick L
03-21-2007 08:37:22
BCnT
03-21-2007 07:54:02
this will work on any engine...either turn engine to TDC on the cylinder youre adjusting so both valves are closed OR turn engine over until one valve in cylinder is completely open and adjust closed valve.
