brass Fitting
A/C bOy
03-24-2007 13:33:32
Anyone know why the brass elbow (that is in the side of the head) has such a restriction in it? This fitting is a 1/8 male to a 1/8 male furrel elbow fitting. The passage way throw the elbow goes from about 3/32" to 1/32". How critcal is this elbow restriction? And why such a restriction? I believe it is the passage way for oil to the valves. Allis Chalmers D-15 series 2 160 ci in engine.
BCnT
03-24-2007 20:57:14
 Re: brass Fitting in reply to A/C bOy, 03-24-2007 13:33:32
you dont need full flow to rockers...just a slight drip is sufficient
Bob
03-24-2007 15:57:12
I would assume it restricts oil flow to the rocker arms to maintain engine oil pressure and prevent too much oil from dumping on the head through the rocker arms.
What's the problem... did you break or strip it?
Sid
03-24-2007 14:32:47
Well I noticed this is the second time you asked this question. Since you did not get a response down below I will respond here. I do not know. Perhaps it is a fitting for a pressure quage.
