3 point hitch for Allis WD
Mike Peot
09-27-1999 11:27:44
I have heard that a guy with a welder could make an adaptor to use 3 pt equipment on an Allis WD.
Are there plans available anywhere for this, I think I could figure it out given enough time but why reinvent the wheel. A really good picture would be helpful too. Just inherited the WD and a Ferguson and would like to be able to swap equipment between the 2 tractors. Thanks
Jerry
10-03-1999 15:04:02
 Re: 3 point hitch for Allis WD in reply to Mike Peot, 09-27-1999 11:27:44
I occasionally see used kits sell at auctions anywhere from $50.00 to $150.00 You definately only want the kind that hooks on the eye bracket beneath the belly.
John
09-29-1999 06:51:20
 Re: Re: 3 point hitch for Allis WD in reply to Frank, 09-28-1999 09:53:50
Frank is giving you very good advise you should heed it.
Ron
09-29-1999 07:03:30
 Re: Re: Re: 3 point hitch for Allis WD in reply to John, 09-29-1999 06:51:20
I agree with Frank and John. You'll be very happy with the Saginaw kit. Don't waste your time trying to cobble one up yourself, life is to short for that. Good luck!
Charlie
09-28-1999 08:31:17
Can't give picture but have seen them that have the bottom links forming a long "V" shape that connects to the regular hitch ppint under the tractor. The "V" is hinged where they meet so the arms can move independently. The adjustments are made like on most 3 pints. Hope this helps
