1941 Allis Chalmers
A/C boy
03-28-2007 17:40:35
Brought her home two days ago after she set in a shed for 5 years. She was stuck. Poured tranny in the plug holes and today she turned over. Compression on all but one. Took valve cover off and she had a stuck exhaust valve. Worked with it a while and it started working. Compression on all four now. It has a magneto.
How can I tell if it is firing?
Dan Slowins
04-07-2007 19:20:47
 Re: 1941 Allis Chalmers in reply to A/C boy, 03-28-2007 17:40:35
I have a 1941 Model C. I had a lot of trouble in the springtime with the magneto. Is it in a dry environment? Pull the cover off and look to see if the comtacts are green. Wipe that stuff off and try cranking it again.
old
03-28-2007 18:33:37
Pull one plug and then hold it on the engine some place. Then turn the engine over a few times. If its fireing you should see a spark if not then you probably will need to check/clean the points which are probably bad. If you need more help with the mag drop me an e-mail and I'll send you a manual for the mag I have one in my computer some one else sent me so when I can I pass it on to others
A/C Boy
03-28-2007 18:52:36
 Re: 1941 Allis Chalmers in reply to old, 03-28-2007 18:33:37
Old, If you get a chance e- mail that manual I did not remember how a magneto works. been a long time, my Dad use to work on a B that my grand dad owned on the farm in North Carolina. I will clean the points and set them at .012 is that correct?
my e mail zachcats@aol.com thanks for your responce.
old
03-28-2007 19:06:53
 Re: 1941 Allis Chalmers in reply to A/C Boy , 03-28-2007 18:52:36
As per the I-T manual you set the points at .020. As far as that manual you need to send me an e-mail first so I can then send you the manual. Just click on my name and it will then take you to a place to be able to e-mail me. My e-mail is always open when I post
