wd 45 tires?
acguy22 in [CA]
04-13-2007 18:11:12
how would 16-9-28s look on a 45 and anyone have an idea on the price for a new set? thanks thinking about buyn some for a 45 we have
big orange
04-14-2007 10:51:14
 Re: wd 45 tires? in reply to acguy22 in [CA], 04-13-2007 18:11:12
16.9x28's will go on the stock rim fine, make the tractor look bigger, had 2 45's with them on, had loaders on both, big improvement over the smaller tires. Wouldn't know what a set would cost now.
wolfman
04-13-2007 20:15:35
Late 45's had 13 in rims & 14.9's are a natural. I guess early 45's had 12 in rims like the old WD's & they had 13.6's. They kind of look too small on a 45 with the higher fender brackets to accomodate the 14.9's. Had a neighbor put 16.9's on a 45 but he used the 15 in rims from a 17. Looked good. I think he did have to cut away a little of the back corner of the fenders.
JMS/MN
04-13-2007 21:20:00
 Re: wd 45 tires? in reply to wolfman, 04-13-2007 20:15:35
Standard on the WD45 was 12 inch tire (oversize on the WD). Oversize on the WD45 was the 13 inch. Early or late did not matter- could order either standard or oversize, same thing with the earlier WD- 11 was standard, 12 was oversize. 16.9, the new size marking, was common on D17 tractors- another step up to handle the extra hp and provide the needed traction.
old
04-13-2007 19:49:15
On stock rims they would be to wide to work/look good. I think max would be 14,9 on stock rims but the 13.9 work real good. New 13.9X28 will still cost around $300 each monuted if not a little more
