D14 Hydrolics Won't Lift
1Farmer
05-07-2007 10:29:06
My D14 has a problem lifting it's arms. Even with little, or no weight it sometimes will not raise the arms at all, or very very slow. Then once in a while it will lift like a new tractor. Usually works better when backing up for some reason. Any ideas???
Texas Denny
05-07-2007 19:15:27
 Re: D14 Hydrolics Won't Lift in reply to 1Farmer, 05-07-2007 10:29:06
1Farmer, sounds like a fluid level problem if it works better in reverse than forward. Have you checked? There are a couple of problems that will result in the hydraulic oil being pumped into the differential.
1Farmer
05-08-2007 10:50:19
 Re: D14 Hydrolics Won't Lift in reply to Texas Denny, 05-07-2007 19:15:27
The fluid level seems fine. Someone told me it could be a plugged "vent". I'm not sure what this would be or where it is located.
El Toro
05-07-2007 16:22:33
You should connect a gauge to your hydraulic pump and see what the pressure is. Hal
