Allis G Tractor..Clutch Won't Engage.
AWB
05-19-2007 17:59:40
I can't get the clutch to adjust properly. The clutch has been completely rebuilt with new springs, new disk facings;and new throughout bearing. I can put the tractor in gear and roll it around quite easily around the shop. No matter how I adjust the clutch adjusting nut the clutch will not engage. When I put the gear shift into gear it doesn't feel abnormal. I'm stumped...where do I go from here. Any help would be greatly appreciated.
NE IA Dave
05-20-2007 16:55:47
 Re: Allis G Tractor..Clutch Won't Engage. in reply to AWB, 05-19-2007 17:59:40
This is not your current problem, but many folks do not know that you should lock down the clutch for extended storage.
AWB
05-20-2007 19:27:28
 Re: Allis G Tractor..Clutch Won't Engage. in reply to NE IA Dave, 05-20-2007 16:55:47
NE IA Dave: Locking the clutch in during storage is a good idea. I do this to prevent the clutch from sticking during storage. Thanks.
AWB
05-19-2007 19:26:21
BCuT: Thank you for the information relating to my clutch problem. I will check out the possibility of a clutch disk being in backwards.
BCnT
05-19-2007 18:39:53
sounds like clutch disc is in backwards
AWB
05-20-2007 19:39:59
 Re: Allis G Tractor..Clutch Won't Engage. in reply to BCnT, 05-19-2007 18:39:53
BCuT: The disk was in correctly. The only abnormal thing I found was that the clutch lever heights were a long ways out of tolerance, and no two clutch lever heights were the same. One lever was over 200 thousandths out of tolerance! Will take it back to the rebuilder. I appreciate the information. I would welcome any further ideas you might have to correct the problem. Thanks.
