A-C WC pressed steel rear end
Jason Strecker
10-07-1999 17:13:32
Does anyone have any information regarding pressed steel rear ends that were installed on the WC tractor? Any information would be greatly appriciated.
GrandadsAC
10-07-1999 17:50:19
 Re: A-C WC pressed steel rear end in reply to Jason Strecker, 10-07-1999 17:13:32
The pressed steel differential housings were used during WWII when cast iron was directed to the war effort. I have heard that WC tractor pullers like the pressed steel housing because of a weight advantage and I have also heard that the steel and cast housings weigh almost the same. I have a spare steel housing but haven't weighed it in comparison to the cast housing.
Dan D.
10-08-1999 14:18:45
 Re: Re: A-C WC pressed steel rear end in reply to GrandadsAC, 10-07-1999 17:50:19
WC's with the pressed steel rear ends are about 400 pounds lighter than the tractors with the cast iron rear end.
Jason
10-07-1999 20:02:10
My cousin has two WC's with pressed steel, one is a '45 model and the other is a '47 model. The '47 doesn't abide by the WWII years. Could this be an overrun? How rare are pressed steel differential housings?
AL
10-08-1999 05:23:00
 Re: Re: Re: A-C WC pressed steel rear end in reply to Jason, 10-07-1999 20:02:10
pressed steel rear ends were bought from gov't surplus during and after the war as a cost savings and fitted to WC tractors....my 43 has one....AL
