WD pull a 3-14 plow?
WD_Fan07
06-22-2007 17:43:52
I have a '51 WD and just picked up a #73 3-14 SLAT-BOTTOM mounted plow for it. How will the WD handle this plow, and how much weight should I use? I just put brand new rear tires on and do NOT want to use CaCl in the tires because it eats up rims, would rather use wheel weights. Any thoughts?
WD_Fan07
06-24-2007 14:08:49
 Re: WD pull a 3-14 plow? in reply to WD_Fan07, 06-22-2007 17:43:52
I also need a new beaming screw, trunnions, etc. as mine are so rusted they are beyond repair. Anyone have a good operating piece? Also I am missing the trunnion cups that fit between the tower and ball and the rear bracket that goes over the rear trunnion ball. Any help would be appreciated.
JMS/MN
06-24-2007 12:07:57
Drop a bottom and add weight. 3-14 will work in sand, but not clay or gumbo. CaCl only eats rims when a leak is not fixed, but other alternatives are available.
Leroy
06-24-2007 07:12:35
Uncle had bought new a WD and 3 bottom plow, not sure of bottom size, now afyter a couple of years the extra bottom was off and laying in abandond barn and just using 2 bottoms. Years later anouther neighbor had a WD and 3-12" plows burn up in barn fire, replaced with a WD and 3-14" plows. could not guide it as pulling front end sideways all the time, said never had that problem with the one that burnt up. Was just that much more of a load. And slat bottoms were never sold in my area and we do have some sticky ground.
old
06-22-2007 19:32:37
There are a number of other fluid you can use in tires to get them to do what you want. 1 is beet juice, 2 is windshield wiper fluid, 3 is antifreeze. And theres probably a few others.
A-C hayman
06-23-2007 17:20:18
 BEET JUICE in reply to old, 06-22-2007 19:32:37
Where in the world would you get a hundred gallons of beet juice? I can't imagine eating enough cans of those things to fill a tractor tire. Turns my stomach just thinking about it!
old
06-23-2007 17:38:55
 Re: BEET JUICE in reply to A-C hayman, 06-23-2007 17:20:18
It also goes by another name but don't rememebr off hand what it is. But yep its beet juice and it doesn't freeze for some reason
Mr Bob
06-24-2007 14:37:01
 Re: BEET JUICE in reply to old, 06-23-2007 17:38:55
It's called "RIMGARD". ie. beet juice.
old
06-24-2007 15:09:52
 Re: BEET JUICE in reply to Mr Bob, 06-24-2007 14:37:01
Ya thats the name. I never have used it so I forgot LOL
LenND
06-22-2007 18:59:54
Years ago we had a 49 WD and pulled a new 3-14 wheel type (not two point) plow and had no problems. No wheel weights but fluid in rear. Our soil is a mixture of light and black clay.
Mr Bob
06-22-2007 18:32:48
I've pulled 3-14's in limestone clay ground with a WD very successfully. This was a 1951 model which had 13.6 loaded rear tires and a 130# wheel weight on each wheel. This tractor had had a "high altitude" kit in it which gave it much more HP than it's origional 34. In easier ground, it would pull the plows with the greatest of ease. If you don't want to use calcium, have them loaded with RIMGARD; it's as heavy as calcium solution and is non corrosive and non toxic.
WD_Fan07
06-22-2007 21:40:25
 Re: WD pull a 3-14 plow? in reply to Mr Bob, 06-22-2007 18:32:48
Any idea what the high-altitude kit consisted of and where I could find one if it would work
Mr Bob
06-23-2007 20:07:59
 Re: WD pull a 3-14 plow? in reply to WD_Fan07, 06-22-2007 21:40:25
I'd contact an AGCO dealer or an experienced Ac mechanic for an explanation. Personally I only know what the results were.
ohio
06-23-2007 02:41:19
flat top pistons for more compression. might as well go .125 over size while it's apart, and think about installing a wd45 crank. or do like i did, and go with a gleaner e engine!
WD_Fan07
06-22-2007 18:07:38
The soil here in SW Minnesota is more of a rich heavy sod and I'm only plowing previously plowed ground so I might try to get away with a little less weight, and thanks for that note on the calcium solution as I have heard stories; obviously misinformed though.
ohio
06-22-2007 18:20:52
 Re: WD pull a 3-14 plow? in reply to WD_Fan07, 06-22-2007 18:07:38
i had previously believed as you do, and was left with skid marks from unloaded tires, staring at something i could'nt move!
ohio
06-22-2007 17:58:02
better put around 500# of weight on each wheel then, assuming you have the black gumbo that a slat bottom plow is designed to work in. if you are plowing sand, an unballested wd will do it, but a slat bottom plow will perform poorly in anything but muck. by the way, the cacl isn't caustic (when good tubes are present), it's condensation that eats the rims. thick black rim grease that truckers used to use, (or a modern epoxy) would allow your rims to last much longer than the 60 years the galvanised ones on my wd lasted! there is no substitute for weight, and while the traction booster will do it's job, you'll be mighty unimpressed with no additional weight. unless your ground is well worked previously, i'd add a couple hundred# to the front, to keep it on track.
Leroy
06-22-2007 17:54:55
May or may not pull it depending on your soil. If you can pull the 3rd bottom off you will be better off.
