E-Gleaner
1000yds
07-07-2007 08:16:40
How does the engine in a E Gleaner compare to the "K" series?
Thanks!
big jt
07-07-2007 09:27:49
 Re: E-Gleaner in reply to 1000yds, 07-07-2007 08:16:40
The K used the Chevy 250. The 292 was used in the F gassers.
The engine in the K was rated at 85 hp. Not sure in the E but think it is rated in the mid 70's.
jt
ohio
07-07-2007 09:43:31
 Re: E-Gleaner in reply to big jt, 07-07-2007 09:27:49
e uses much more durable (than chevy six) but slightly less powerfull g-226 engine, same as d-17. although, if you look @ the torque curve, the allis 4 has alot more under 2000 rpm. (i've heard something like 300 lb.-ft. @ 850rpm) it also is an almost direct replacement for anything with a 201" or 226" engine. it makes between 50-60 hp, but it has pistons that fall way short of the deck, and compression is easy to come by, and more hp. is easy to come by.
ohio
07-07-2007 09:43:04
e uses much more durable (than chevy six) but slightly less powerfull g-226 engine, same as d-17. although, if you look @ the torque curve, the allis 4 has alot more under 2000 rpm. (i've heard something like 300 lb.-ft. @ 850rpm) it also is an almost direct replacement for anything with a 201" or 226" engine. it makes between 50-60 hp, but it has pistons that fall way shot of the deck, and compression is easy to come by, and more hp. is easy to come by.
JMS/MN
07-07-2007 09:04:38
E used the D17 engine, K used a GM six cylinder, something like a 262 or 292.
