wd 45 electrical
1bstan
07-25-2007 23:36:06
father in law recently passed away.up to me to get farm ready for sale.has wd-45 w/ no battery. is it a 6v or 12v system.any help appreciated
JMS/MN
07-27-2007 12:31:45
 Re: wd 45 electrical in reply to 1bstan, 07-25-2007 23:36:06
If it's the original 6v, it's also positive ground.
Jerry Coulter
07-26-2007 04:59:26
If it is a WD45 gas tractor and still has an OEM generator on it, it will be 6 volts. If a WD45 diesel, it will be 12 volts. If converted to an alternator charging system, it likely is 12 volts. I can't believe anyone would ever put a J C Whitney's 6 volt alternator on a tractor.
CWL
07-26-2007 10:42:54
 Re: wd 45 electrical in reply to Jerry Coulter, 07-26-2007 04:59:26
Hard to believe, but it does happen. Dad bought a 9N ford with a delco alternator on it years back. It didn't have a battery in it so we put a 12 volt one in. Wouldn't hold a charge. After some investigation we checked the alternator output and found it to be low. When we pulled it off to replace it we found a 6V stamped on it.
