wd 45 / wd
ac dave
08-25-2007 08:09:40
is the 45 that much better tractor than the straght wd never owned a wd and never operated one just wondered if anybody had any thoughs about them David
CheeseheadFred
08-29-2007 20:48:52
 Re: wd 45 / wd in reply to ac dave, 08-25-2007 08:09:40
Having spent a lot of time in the drivers seat of both the WD and the WD-45, the biggest difference was hooking to a three bottom plow or a 12 foot disc. Our WD-45"s would walk with them in third gear, while the WD"s needed second gear. Otherwise, both models with wide fronts were good loader tractors, snow movers, corn planters, mowers, rakers, and balers, etc. etc.
Kent of SWMO
08-26-2007 14:25:12
Stock WD is about 33 PTO HP. WD 45 Is 45 PTO HP. In the right place 12 more HP would be better.
Kent
Rock_Picker(MO)
08-25-2007 16:39:11
I have a late model WD with the curved shift lever. Use it to run a 7 foot brush hog. Cut weeds and small brush that are as tall or taller than the tractor. Plenty of power. Good fuel economy also. Get a "hankerin" for a 45 now and then, but don't really need it. Someday I'll probably get a 45 just to "have" it..... ...FWIW....RP
old
08-25-2007 09:43:00
The WD and the WD45 are almost the same tractor. Big difference is that the WD45 has about 10 more HP then the WD has. Both are 4 speeds and both have hyds and hand clutch. To the common man they look like the same tractor and thats why there are so many WDs sold as WD45 when in fact they aren't what people say they are. Seen a good many WDs at shows that people have posted signs o and said that the tractor was a WD45 when in fact it was a WD instead. Big difference is the engine in them. Ya the trannys are a little different also but again not by that much. Control are pretty much the same on both also. Theres a few picture of both in my web site
Will Herring
08-25-2007 09:34:11
Not necessarily. Just a bit more power under the hood is all, but my straight WD is all I could ever ask for. Mostly easy to work on, runs good, and has good pulling power (I figure around 37 HP). Good enough to work a small garden with and use a pull type rotary mower and do various other work with smaller equipment.
