Flywheel locked on AC-HD6G
Arthur
10-21-1999 19:59:12
I am having problems with my track loader not starting. I took the starter out and it seams to be working fine however, the flywheel is locked and I cannot make it move at all. I tried moving it with a crowbar but it would not. Any advise on where to go from here?
Lee Bradley
10-22-1999 09:15:31
 Re: flywheel locked on AC-HD6G in reply to Arthur, 10-21-1999 19:59:12
I would remove the driveline between the engine and transmission in case the transmission is stuck and the clutch isn't releasing. Next I would disconnect the hydraulic pump in case its stuck. If the engine still will not turn, its probably time to remove the engine and the first two steps are required any way. Sounds like a blown engine.
Lee Bradley
