WD starter question
AGR538
09-14-2007 17:58:19
For those of you who so kindly helped me with my mag problems a few days ago, thank you and your suggestions worked and I finally got fire. It started after being dead for over two years but when I went to take off it died. I went to start it again and it turned over a few times, felt a pop and the starter will not turn it over again. How do I take the starter off? And no, I have not bought the $30 IT manual yet and Tractor Supply still has them wrapped in plastic so I can't go to the store and look up my questions for free. Yes, I reached that emotional peak every tractor nut feels when he gets a recently purchased tractor started. Yes, I hit that emotional low when it would not turn over again.I can't go on living life this way.
wddave
09-15-2007 06:08:05
 Re: WD starter question in reply to AGR538, 09-14-2007 17:58:19
Use the crank and turn the engine over just a bit to see if the starter is locked. If the ring gear is worn the drive can jam as it trys to engage.
Sid
09-14-2007 19:28:55
It is a long shot but I have had that bolt them guys are talking about work loose and the starter would bind up.
spinwv
09-14-2007 18:18:56
AGR538, On my 1950 WD left side as you sit on the tractor, just in front of the starter, about an inch, is a bolt (about 5/8) with a bigger nut under it. After the obvious battery, wire stuff, Losen the nut and back off the bolt. The starter should fall right out.
old
09-14-2007 18:15:39
First off check all battery cable connections one may have got dirty. To pull the starter look at that area and you will see a botl with a lock nut on it. Loosen the lock nut then take out that bolt, the end of the bolt is tappered once its out you should be able to twist/turn the start and slide it out. They can be fun some times because rust builds up and makes them hard to pull out
