Grader
8n 9n
09-18-2007 17:17:22
Hi my uncle has an Alice Chalmers grader, I am looking for some information on this tractor. I think that it might be a 1947, but I could be wrong. Any help would be apreciated.
8n 9n
09-24-2007 10:09:50
 Re: Grader in reply to 8n 9n, 09-18-2007 17:17:22
yep its the same as the one you have old. Neat machiene. Only this one is painted company colors of the guy we bought it from.
old
09-24-2007 11:52:46
 Re: Grader in reply to 8n 9n, 09-24-2007 10:09:50
I've used this one I have for about 15 years now. My drive way is a mile long and then I also have to keep up my moms drive which adds another 1/2 mile of drive and it does a good job but almost takes 8 arms to use it. LOL. What it really is, is a WC tractor that Allis cut the front ends off and then added a longer front and a wide heavy duty axle to. The added the blade and hand wheels. Almost all WC parts will fit other then steering and most of that is the same also
8n9n
09-25-2007 04:54:01
 Re: Grader in reply to old, 09-24-2007 11:52:46
I have never used it for any work, just to drive it around, I would like to see it painted and restored because from what ive been told they are fairly rare. Round here anyway. We need to pull one of the tires and wheels off to fix the nonexistent brake.
old
09-25-2007 09:31:08
 Re: Grader in reply to 8n9n, 09-25-2007 04:54:01
To fix the brakes you don't pull the wheel off there band brakes and can be installed from the top. Parts for fixing the brakes are HIGH at around $100 per band, I checked into that a couple years ago because mine has only one working brake on it.
old
09-18-2007 20:37:23
If it is for sure a 1947 it would have to be a WC Speed Patrol. See my web site for a picture of one. I own a 1947 WC SP which is pictured in my web site
wdTom
09-18-2007 17:50:15
Is it a full size grader or one made from a tractor with a longer frame on the front? Allis made different models of both types.
