wd 45 smoking
ac dave
10-02-2007 17:05:53
i bought a wd45 and the guy said it smoked a little well i think it smokes quiet a bit and is pumping oil out of the no 3 cylinder i was just wondering if it might be a stuck ring i believe the tractor has set a while and is there an easy fix for it if thats the problem thanks Dave
ac dave
10-04-2007 08:33:31
 Re: wd 45 smoking in reply to ac dave, 10-02-2007 17:05:53
well i tore into the 45 last night the rocker arm assembly had 2 broken shaft supports pulled head off no 3 piston is pitted and so are the valves on no 3 but the piston seems tight the cylinder seems in good condition just a little ring ridge so i am gonna clean it up and fix the rocker arm put it back togather and see what i have maybe i am lucky this time i will know in a couple days thanks for the reply,s David
old
10-02-2007 21:02:53
Heres how I deal with that type of problem. Fill all the cylinders with tranny fluid. Then walk away from it for a day or 2. Pull all the plugs out and spin it over to clear out the tranny fluid. Start it up and run it and if you can work it hard for an hour or so. If it then clears up it was a stuck ring or valve if it doesn't then it time to open it up and rebuild it
BrianA
10-02-2007 18:37:06
Could be rins or valve seals? I'd run a compression test on it to see. Check it dry first then put a tablespoon of oil in the second time and see if the compression comes up,if it does it's rings. I would also check it against the other cyls.
mlpankey
10-03-2007 00:31:05
 Re: wd 45 smoking in reply to BrianA, 10-02-2007 18:37:06
aint no valve seals on a 226 engine could be worn guides or rings but not valve seals
