6060 rough running
180doug
10-07-2007 16:28:36
Neighbor has a 6060 that was running great ; now it smokes terrible ,no power, you can stall it at wide open by putting on the brakes in reverse; it is running rough, I changed the fuel filters ,no difference ; Now what???
cadet trooper
10-08-2007 15:41:12
 Re: 6060 rough running in reply to 180doug, 10-07-2007 16:28:36
This is just a thought but you may want to check to see if the turbo is locked up because that little 4 cyl. has virtually no hp without the blower it's easy to check by removing the intake hose from the air cleaner at the blower and reach in and see if it spins and make sure if it's OK to fasten the hose back where it was to make sure no dirt or anything gets in there. Again this is just a thought, good luck CT.
greatwest
10-07-2007 20:15:17
could be an injector stuck open, could also be plugged exhaust too or valves not set correctly or air cleaner plugged....
good luck!
C
