m100 series B
Alan A
10-09-2007 10:02:06
ust bought a solid old m11 series B. It came with a couple of old batteries on a 24 V system. They were hooked up positive ground. Before putting new batteries in I wanted to make sure that this is really a positive ground system. Can anyone help? Also I need a good market for AC heavy equipment parts. I talked to Pat Kelly Eq. in St. Louis. The guy there was nice enough but didn't sound real excited to deal with that old a machine. Any Advice. Thanks.
Alan
Harry J. Case
10-10-2007 20:50:02
 Re: m100 series B in reply to Alan A, 10-09-2007 10:02:06
Alan Sounds like you have a pretty rare piece there, found it in C H Wendalls A C Story page 203. Thanks for the info. Harry
Alan A
10-11-2007 06:20:46
 Re: m100 series B in reply to Harry J. Case, 10-10-2007 20:50:02
I've used it about 10 hours to cut ditches and grade in a road base. It seems like a really solid old machine. It tends to kick out of low range when there's slack in the drive line and the turn table will spin ocassionally, but I'm really happy with it so far. Now I need brakes. That will probably be a big challenge. It looks like a hydraulic assist on the cylinder. I still need a good source for parts if anyone can help.
Alan
Kentb of SWMO
10-10-2007 05:54:42
Allis-Chalmers used positive ground until they started equipping their equipment with alternators.
Kent
Alan A
10-10-2007 07:02:44
 Re: m100 series B in reply to Kentb of SWMO, 10-10-2007 05:54:42
Thanks Ken. That's what I needed to know.
Alan
Alan A
10-10-2007 07:02:33
Alan
steve(ill)
10-10-2007 05:46:31
an M100 is an old motor grader, probably about 1950, probably about 100 HP.
ohio
10-11-2007 12:49:54
 Re: m100 series B in reply to steve(ill), 10-10-2007 05:46:31
196?, 130 or so hp. n.a. 516" 10000 motor, 24v positive ground.
Harry J. Case
10-09-2007 20:07:32
Hey Alan What exactly is a M100 series B? just courious, Harry
Alan A
10-10-2007 07:00:46
 Re: m100 series B in reply to Harry J. Case, 10-09-2007 20:07:32
Sorry Harry, I should have mentioned that the M100 is a motor grader.
Alan
Alan A
10-09-2007 10:05:45
Sorry. That should have read an M100 Series B Allis Chalmers.
Alan
