d17 runs rough
acdave
10-15-2007 19:45:27
my d 17 is not running right i replaced the coil and points still runs rough back fires through the exhaust idles smoth but when u rev it up it gets rough any idea's i could use the help thanks dave
greatwest
10-18-2007 07:50:36
 Re: d17 runs rough in reply to acdave, 10-15-2007 19:45:27
Backfire out of exhaust is timing too late, backfire out of carb is too early!
Hope it helps, GW
chuck davis
10-18-2007 05:36:46
It could also be bad wires, or a manifold leak.
DavidKittle
10-17-2007 10:46:03
Acdave:
I had the same problem with my D-17.
Turned out that the yellow wire from the coil to the ignition switch had a BAD connection on the ignition switch.
Cut the bad end off and crimped on a new terminal and never had a problem since.
Hope this helps.
Obsession
10-16-2007 19:30:22
Sounds like it has to be fuel or ignition. Is the gas old? Make sure the sediment bowl is not plugged. Un hook the fuel line from carb and see if you get good fuel flow. Pull one plug wire "one at a time" to test for a bad plug or wires. If this does not work try spraying carb spray in the tractor at faster RPMs to see if it smoothes out. If it does you may have something plugging your carb and it may need a rebuild.
acdave
10-16-2007 18:16:28
i changed the plugs plug wires coil and points rebuilt the card and still backfires through the exhaust misses takes gas poorly as well hmmmmm any other ideas where to check thanks David
DavidKittle
10-19-2007 17:07:07
 Re: d17 runs rough in reply to acdave, 10-16-2007 18:16:28
acdave;
Did you ever check the timing to make sure that it is firing at the right time?
DavidKittle
10-19-2007 17:05:17
acdave...
Did it just start having problems,or have you been having these problems?
Jerry Coulter
10-16-2007 05:41:27
A new set of 45XLS spark plugs solved my problem.
Eldon (WA)
10-15-2007 19:59:34
I would take the carb apart, soak it, and put a kit in it.
