7030 gear problems
aFORDable
11-01-2007 16:45:30
Need a little input please. We parked our 7030 last evening with no problems. I get in it this morning to disc and it will not go in gear. The floor shift works fine but the two speed shift (turtle/rabbit) will not engage. It seems to go in low range but when I let out on the clutch nothing happens. I can not get it in the high range it won't push in that gear at all. I'm new to the AC world so any input is appreciated.
856 puller
11-02-2007 05:26:43
 Re: 7030 gear problems in reply to aFORDable, 11-01-2007 16:45:30
do the hydrulics work? the buttons on the floor are a hyd. clutch setup if the torque limiter fails it wont drive the pumps and will go in and out of gear with out grinding
Jack a
11-02-2007 04:17:47
Probably the shift cable itself or a yoke on the cable or a pin fell out of a yoke.
Texas Denny
11-01-2007 20:27:01
This is a lot newer than anything that I've dealt with but there may be similarities to some I have. Perhaps someone else will give more pertinent info.
I have a tractor with this hi-low feature that you describe. Since you can't get either high or low to work, I would guess that something has happened to the shift linkage. I'm not familiar with this tractor so I don't know what the cover looks like that you will need to be remove to examine the linkage. On mine, the whole transmission, rearend and hydraulics need to be removed. Hopefully yours will have an inspection plate.
