Allis B rearend and ram
1979Ford
11-03-2007 17:58:29
What weight oil is used in the rearend of a B Allis? I assume the ram uses the same oil since it works off of the transmission. Is it hard to work on the ram? Mine is leaking in the front, it needs the seal replaced. My B has a belly mower and it is hard to keep it at the correct height because the ram leaks so bad.
