Allis Chalmers tractor - Model wd45
.Billie Furgers
11-05-2007 09:33:37
need to know about the hydraulic pump, and where is the filter? We are having a problem lifting round bales of hay, using the front loader. Sometimes it will lift high, and sometimes only a few inches high. contact me by phone at (309)647-0931 let me know which manual I need to order.
Thanks
Texas Denny
11-05-2007 19:08:54
 Re: Allis Chalmers tractor - Model wd45 in reply to .Billie Furgerson, 11-05-2007 09:33:37
There is no filter. If you are using a loader, you need to be certain that the you have enough oil in the hydraulic reservoir to handle all four cylinders. Allis suggests having the lift arms raised to max and your loader cylinders raised to max while you check the oil level in the reservoir. Low oil causes erratic performance.
The other thing is that you may be exceeding the capacity of the lift cylinders. If you need to lift more than the capacity of the lift cylinders, you will need larger diameter lift cylinders.
