Removing Rust from Steel Shims.
AWB
11-08-2007 18:13:58
How can rust be removed from steel shims?
DARDAN
11-12-2007 20:58:39
 Re: Removing Rust from Steel Shims. in reply to AWB, 11-08-2007 18:13:58
Those little stainless steel (toothbrush sized) wire brushes work pretty well, and they will tolerate a little toilet bowl cleaner to assist.
Dick L
11-09-2007 06:32:12
I would use the rusty shims as a pattern and make new ones. You can buy shim stock different thicknesses at NAPA or such by the sheet. What area are the shims for?
steve(ill)
11-09-2007 05:30:00
for a few shims, i would probably lay one on a table top and hold down with one hand. take a piece of 100 grit sand paper and sand one side by hand, rotate 90 degrees and keep going... if i had a lot of parts i would try electrolyis.
