Final drive on WC
8n 9n
11-21-2007 14:24:04
On a WC grader that my uncle owns the final drive on the left side was making a grinding side and will not move. We have not yet had it apart and would like to know if it is gear to gear, chain drive, etc. If anyone has a diagram or pictures of this drive please post them here.
Thanks, Ben
8n 9n
11-23-2007 05:12:15
 Re: Final drive on WC in reply to 8n 9n, 11-21-2007 14:24:04
Thank you that helped tremendously. Thanks, Ben
LWD
11-22-2007 00:02:00
If your lucky it might be a sheard key.
Joe M(GA)
11-21-2007 16:38:13
see if this will get you started-
third party image
third party image
old
11-21-2007 15:45:34
The drive on the WC speed patrol is the same as on the WC tractor. Its gear to gear. I would start off by pulling the oil pan off the drive on the side that has the trouble and look for broken gear teeth and or balls from a bearing. I own one of those my self and they are neat toys and it takes 8 arms to use one. Pictures of mine in my web site. All a WC Speed patrol is, is a WC tractor that has been made longer and had the wide front and blade put under it
