1938 B rims
What can I use ??
Gary Reider
11-02-1999 14:22:31
I understand that rims on 1938 are not the same as later B's. Can I use "4-loop " 8-24 or 9-24 rims and bolt them to the wheel centers instead of using OEM wedge clamps and Oem style rims??
Mike Meyer
11-04-1999 12:38:41
 Re: 1938 B rims - What can I use ?? in reply to Gary Reider, 11-02-1999 14:22:31
As Chris said, the rims will work but you need to get smaller diam. bolts. Also the wheel center is a bit larger around. The new rims will kinda wedge to the wheel center rather than bolt flat to it. On mine I put brass bushings in to take up the extra space for the bolt holes. Cut them to length so they went from the back of the bolt hole on the wheel to just short of the rim loop so it would tighten up.
Chris
11-03-1999 18:45:23
Yes you can use 4-loop rims. They are different but the difference is only when you use the ecentric bolts that came with them. The bolt hole sizes are different. Using new bolts and 4-loop rims eliminates any difference or concern.
