Marvel Schebler TSX 853
alliswd45
12-17-2007 15:03:51
What would the Marvel TSX 853 be used on, i got a combine motor out of a gleaner E, 226ci, but i can"t find a rebuild kit for the carb. Does any one know where i can get one or know anything about the carb
Jeff Z.
12-19-2007 02:49:47
 Re: Marvel Schebler TSX 853 in reply to alliswd45, 12-17-2007 15:03:51
Rebuild service. They do Marvel TSX carburetors.
http://www.nationalcarburetors.com/industrialcarburetors/industrialcarburetors.aspx
noncompos
12-17-2007 21:22:16
Someone said zenithfuelsysyems.com also had some Marvel-Schebler kits...
Jeff Z.
12-17-2007 20:35:05
Did some more checking and it sounds like an OK carburetor for a Allis 226 engine.
These things are a pain to research.
I have heard of that number being used on a D-17 226 but I don't think Allis ever put it on, but there are alot of tractors out there with different carburetors than what they came with that run fine.
Jeff Z.
12-17-2007 20:13:59
Did a little checking and I think it was on Allis combines and cotton pickers.
Jeff Z.
12-17-2007 19:50:46
I can't find that carburetor in my Allis tractor listings either.
Try giving these people a call for a kit.
Tony's Tractor
Robert's Carb
The Carburetor Shop
All can be found on Google.
old
12-17-2007 19:31:48
Well I looked in my catalog for that carb but didn't find it. But on MS carbs they made 3 or 4 different sizes of them and the kits will fit as per size of the carb. I.E. A carb for a ford 8N will use the same kit as for an Oliver 60 and the kit for the others are the same. So take the carb gasket to a good parts store and compare the gaskets in each kit
