D17 Charging Issue
Smith1000
12-27-2007 18:19:02
I bought a non-running D17 last June and managed to get it running with some help from Old and others on this forum. Remarkably, it runs very well. It was missing a piece from the carburetor. I ended up really using the tractor fairly hard to put up hay. Since I have had it, I don"t believe it has ever charged the battery. It runs down and I eventually hook the charger on it. It has a Delco Remy voltage regulator. Don"t those old regulators have to be adjusted or crossed from terminal to terminal with a wire to get it referenced right? I can"t think of the term for it---polarized, I think. If the generator is no good, would I be better off putting in a GM alternator or would it be wiser to have the generator rebuilt? Thanks.
Smith1000
12-28-2007 15:58:45
 Re: D17 Charging Issue in reply to Smith1000, 12-27-2007 18:19:02
Many thanks for all of the pointers. I will trouble shoot the system closer tomorrow based on this information. Maybe I can get this system charging. If not, I"ll put in an alternator. This Allis is 12v with negative ground. I believe it is a later model because it has power steering. None of the gauges work, including the gas gauge which spins around and around.
I have had a solar panel sitting on it to keep the battery up. It continues to start. Had to replace the key switch though. Thanks again.
El Toro
12-29-2007 14:32:25
 Re: D17 Charging Issue in reply to Smith1000, 12-28-2007 15:58:45
You should look at the brushes in your generator
to see if they need replacing. I have a 12 generator on my garden tractor and it is also the starter. I replaced the brushes once in 36 years.
Take the ground off your battery and clean those terminals on the regulator and the wire lugs or spades too. Hal
loveshisallis
12-28-2007 12:31:44
third party image
Hello;
I had that problem wit my D-17 and found two problems. I couldn"t adjust the voltage regualtor, so I bought a new one made in the good old U.S. of A. then the gnerator was terrible dirty on the commutatot. Took it apart , and used plumbers crocus cloth to clean it up. Brushes were good on min.
I know that you put the voltmeter across the battery and while running it should get to say 14 volts. When I adjsuted my higher, it would start to " perculate"...too high. (Yes I know that the book call for 14.8, but I am talking about what worked and keeps on working.
Read what John T has to say also!
togethjer we will get it going...
happy holidays
Jack a
12-28-2007 05:14:46
Check to see if the brushes are froze up.
old
12-27-2007 21:36:35
Genny systems are ok but my self I know little about them. If it where my tractor I would switch it over to 12 volts and use a delco 10si alternator on it. Alternators seem to work better with less trouble then a genny system does plus fewer parts to worry about. We just switch my sons 1950 chev over to an alternator because of that reason. I don't want to have him call me some time late at night because his genny stopped working so we did the alternator thing to it.
John T
12-27-2007 20:12:49
Smith, its late n your questions a wide open one so to save myself time I will just post my complete n long winded Non Charging Troubleshooting Procedure which covers Polarizing n you can go from here. Para 5 is an easy way to see if its a genny or a VR problem. The VR and genny BOTH need a good ground and the belt needs to be tight rememebr. (See below)
PS If you desire originality fix the genny but if you want a better charging system convert to an alternator.....
TROUBLESHOOTING CHARGING SYSTEMS
ARE YOU SURE THE AMMETER IS WIRED CORRECT AND WORKS????? If you turn the lights or ignition on (if coil ignition not a mag) when she’s not running, the ammeter should swing over to the - discharge direction, does yours??? Are BOTH the ammeter terminals reading hot battery voltage?? They MUST !!!!! ! There’s but one wire on the ammeters Supply (from battery/starter) terminal while its other Load terminal wires to the BAT terminal on a Cutout relay or VR PLUS wires to feed loads like lights or ignition, unless where a 4 terminal VR is used where lights n ignition are fed from the LOAD terminal on the VR.
To Polarize the Generator, first temporarily dead ground the Gens Field post to case/frame, then momentarily flash jump a wire from the Cutout Relay or VR's "BAT" terminal over to its GEN (or ARM) terminal and you ought to get a small spark. Same things accomplished by momentarily flash jumping a hot wire (BAT terminal on Cutout Relay or VR or starter post etc) direct to the Gens ARM post to get the spark.
TROUBLESHOOTING A CHARGING PROBLEM IN CLASS A DELCO TYPE SYSTEMS
1) For a good working Gen to get to and charge the battery, it has to have a path usually from the Gens ARM post,,,,, ,,,,to and through the Cutout Relay (between its GEN and BAT terminals, regardless if on a VR or Relay),,,,, ,,,up to the Load (NOT to battery) side of the Ammeter,,,,, ,,,to and through the Ammeter,,,,, ,,,,from BAT side of Ammeter to ungrounded battery terminal, often via the starter lug post. Is yours wired that way or equivalent ??? The ammeter should read hot battery voltage on BOTH terminals, does yours??? Even if an ammeter were stuck (but still continuous) as RPM increases the battery voltage should rise from 12.6 to near 14 volts and/or the lights glow brighter (half that on 6 volt systems). Have you tried that in case the ammeter isn’t working right?????
2) If the above is so, the BAT terminal on the VR or Cutout Relay MUST ALWAYS READ HOT BATTERY VOLTAGE. Does yours??? If not, the Gen cant get to and charge the battery.
3) The Gen to VR (if it has one) wiring is as follows:
BAT on VR to ammeters load (NOT battery) side
ARM (or GEN) on VR to Gens Armature post.
FLD on VR to Gens Field post.
(L) Load (if you have a 4 wire VR) up to BAT supply input terminal on switch to feed loads like lights and ignition.
WIRING ON CUTOUT RELAYS: They wire BAT side to ammeters Load terminal,,,,, GEN side to gens Armature post. On cutout relay systems, the Gens Field post is wired to the light switch where it gets a dead ground for high charge or a resistive ground for low charge. Therefore, there must be a good connection from the Gens Field post up to the switch PLUS the switch is good and it’s well grounded !!!!! !!
4. THE GEN AND VR OR CUTOUT RELAY MUST BE WELL GROUNDED AND THE BELT GOOD N TIGHT. If any doubt, run a ground wire from the grounded battery post or clean solid frame member direct to the Gen and see what happens????? ????? ????? ????? ????
NOW, if the Gen and VR are grounded,,,,,all is wired correct,,,,, ,,BAT terminal on VR or Cutout Relay is HOT,,,,, ,,Belt is tight,,,,, ,,,Ammeter is good n continuous n works but she wont charge, have you had the batteries tested lately????? Is there electrolyte above all the plates and no cells have a gray or milky appearance????? A bad battery may not accept a charge you know!!!!! !! If the battery checks okay, proceed below to see if its a Gen or VR problem (AFTER you have insured the wiring per the above)
TO DETERMINE IF ITS A GEN OR VR OR CUTOUT RELAY PROBLEM
5. a) VOLTAGE REGULATOR SYSTEM: With the tractor running, temporarily ground the Gens Field post to case. If she charges then but NOT otherwise, the VR may be bad, or a wires missing from VR's Field post to the Field terminal on the VR, or the VR isn’t well grounded.
b) IF IT’S A CUTOUT RELAY SYSTEM and she charges only if you dead ground the Field but NOT otherwise, its either a bad switch or the switch isn’t well grounded or else the wires bad or open from the Gens Field post up to the switch. INSURE THAT GOOD SWITCH GROUND AND WIRING
6. If she still don’t charge, leave the Field grounded and jump a wire across from the VR or Cutout Relays BAT terminal over to its GEN terminal (jump by passes the cutout relay) and see if she charges. If then but not otherwise, a VR's cutout relay isn’t working correct (maybe points burned/carboned) or a Cutout Relays NOT working or not wired correct.
7. With the 2 steps above, you have basically by passed the VR or Cutout relays functions, so if she still don’t charge, you're left with a bad battery or wiring or the Gen itself.
8. MOTOR TEST. You can Motor test the Gen. If its grounded and you remove the belt and apply hot battery voltage direct to its ARM Post and have the Field Post dead grounded to frame, it should motor n run well (Armature n Brushes and Commutator likely okay). Then, if you next remove the Fields ground and it speeds up some, the Fields probably good. If it passes both those tests, it should charge, and if not, it may be a wiring or battery or grounding problem. The hot battery voltage may be taken off the VR's BAT terminal or the starter post or the battery itself for this test.
9. Typical Gen problems may be the brushes are worn down or the hold down spring assemblies are stuck/corroded/dirty and arent pushing the brushes tight down against the commutator. Check those things out. Worse may be bad fields or armature etc. Air and WD 40 etc can clean and free them, the hold downs must be free n snap and hold the brushes DOWN TIGHT and they cant be worn down too low.
SUMMARY: Check the wiring,,,,,the grounds,,,,, insure BAT on VR or Relay is hot,,,,, ,check battery (maybe load tested and Specific Gravity checked),,,,, ,,,good tight belt,,,,, ,insure ammeter is continuous (BOTH sides HOT),,,,, see if battery voltage rises above 12.6 (half that for 6 volt system) and/or light glow brighter,,,,, ,,,do the Field and cutout relay VR by pass checks,,,,, ,,insure the Gens brushes arent worn down and the hold down springs are free n clean and push the brushes down tight,,,,, ,,,,,check the connections,,,,, ,,,try the Gen Motor Test to see if its good.
You may just have a bad battery or bad ground or connection if the Gen and VR or relay are okay. Good Luck n God Bless, let us all know.
John T Nordhoff in Indiana, retired electrical engineer who usually lurks over on the Mother Deere pages instead of over here on the "dark side" lol
CENTAUR
12-27-2007 19:52:08
If this were mine I would take the generator off and dissasemble if I would not find any burnt segments in the armature,which would indicate a bad winding attached by the solder being melted off the segment.A bad segment will shorten the life of the brushes very rapidly.If the brushes are shortened after all these years,replace them after cleaning by sanding with a strip of sand paper.Next the VR needs to have a good ground and all the points filed smooth with a regulator file which is finer toothed and much thiner then a reg.point file.A thin(#2FLEXSTONE)is preferred as it polishes as it smoothes.The drive end bearing is the same one used by all auto generators and alternaters. CENTAUR
steve(ill)
12-27-2007 19:45:47
the regulator has 3 or 4 terminals. F(field), B(battery) and G(generator). you touch a jumper from G to B with motor off, then start it up. if that dont work, put a jumper on F to ground when running and see if it starts to charge. if that dont work, put a volt meter from "G" to the hot terminal on the battery when running (with F grounded to frame) and see if the generator is putting out. try to narrow down if problem is generator output, or regulator control.-- a good delco alternator with internal voltage regulator from any chevy truck, 1975-85 is a good choice if you are upgrading--- also, see if you are negative or positive ground right now. original was positive, might have been changed.
