1210 David Brown hydraulics
Fred Brown
07-04-2006 14:46:13
I have a DB 1210 with ~6000 hours. When hooked to 3 point backhoe, the hydraulics seem weak, especially after running for a few minutes. I changed hydraulic fluid and filters not long ago. Would the pump be wore out, or might the relief valve be sticking or leaking by? Any ideas on how to check? I can rig up a high pressure gauge to one of the outlets to check pressure. (I did this a couple years ago when I was having problems with a logsplitter, had 2000 lbs pressure then) This problem seems to have happened suddenly, I would think a pump would get weak more slowly.
Also noticed when planting, the 3 point hitch arms sometimes jump a bit (nothing attached to them) when the remote cylinder is activated.
Thanks for any ideas.
Fred
richard in nz
07-05-2006 22:47:02
 Re: 1210 David Brown hydraulics in reply to Fred Brown, 07-04-2006 14:46:13
Have you cleaned the bypass valve?
Fred Brown
07-06-2006 14:51:34
 Re: 1210 David Brown hydraulics in reply to richard in nz, 07-05-2006 22:47:02
Richard: I haven"t cleaned the bypass valve. Where is it, and any tips on how to do this?
Thanks, Fred
Rclemons
07-04-2006 17:49:42
What fluid did you use when you changed it.
Fred Brown
07-05-2006 09:53:55
 Re: 1210 David Brown hydraulics in reply to Rclemons, 07-04-2006 17:49:42
I used the Case hydraulic oil, I think its called TCH. Its the same as what we"ve used all along.
