Need help Identifying Case Tractor
Steve Page
07-06-2006 12:55:24
Nedd help in identify the model number etc so can order parts for a case tractor.....from the color scheme on the tractor and phot5os I have looked at on the net it is a 1955 or later....it has a tricyle front end....colors are creme and orange .... has a swing out grill with a round case logo in clear plastic above the grill... has two head lights mounted back by the driver on the hood ....is four cylinder gas .....it looks very similar to a tractor that I looked at on this site .....a 1956 311 or 300 ....except the the rear wheels on mine are not solid but are kinda like spokes about an inch lide and 1/2 to 3/4 inches apart..... if you can help please let me know.....email at address listed or at stevepage@netscape.com or call me on my cell at 1-479-806-1875..... Thanks for any help!
John Noname
07-06-2006 18:34:17
 Re: Need help Identifying Case Tractor in reply to Steve Page, 07-06-2006 12:55:24
Does the exhaust come out the side or is it underneath? The last "300's" were 350's with 42 HP. The 300 is rated at 34.9 per our Case dealer when we bought a 300 new. One of the best little tractors Case ever built.
Joe (Wa)
07-06-2006 14:11:08
Sounds like one of the general purpose model tractors in the 300 series. The model/serial nr tag, if it still exists, will be affixed to the dash down below the steering column (you'll be looking up with a crick in your neck).
Joe
Steve Page
07-06-2006 15:38:58
 Re: Need help Identifying Case Tractor in reply to Joe (Wa), 07-06-2006 14:11:08
Guys..... ...think I might have confirmed my suspecions after lookingg at a photo of ED Elwell's 1957 Case 300 ..... .it looks like mine including the spoked rear wheels..... .am I right.....now what engine does it have..... 188 or the 230?
Steve Page
07-06-2006 15:23:41
Joe..... .thanks for the info.....unfortunatly we looked there and all that is ther is the outine of where the tag was....anyother ideas.....and I do think from the photos I have looked at that it is a 300 series probably from 1955 up ....the only differences I see from the photos is the ones I have seen have a solid rear wheel and this one has a flat spoked wheel that uses a bolt clamo to secure the inner wheel to the rim!....only real number other than casting numbers is a number stamped on the engine on an area specifically put there for stamping a numbber on the right rear side of the engine..... .stamped there is 110N2156
Joe (Wa)
07-06-2006 17:30:01
 Re: Need help Identifying Case Tractor in reply to Steve Page, 07-06-2006 15:23:41
The 300 series round nose tractors were built in 1956 & 1957. The gas engine is 148 cid, tractor generally rated 30-33 hp PTO & 28-30 hp drawbar.
Engine serial nr 110M + 5 digits is the only one I've have seen in the gas 300 series. Doesn't mean 110N + 5 digits isn't common, just haven't seen any.
Case parts manual R.I. A324, lists the rims you have for models 302 & 312. I don't know if they will fit other 300 models.
Joe
